Botev12 Posted June 8, 2010 Report Posted June 8, 2010 Hi. Ive been trying to set my gain since i blew my tweeters some time back ago. But failing to get a hold of a DMM with O-Scope it looks like I have to try the DMM-Voltage way. The setting with hearing I find a bit "unreliable" and my hearing is not what it used to be. The forumla I'm not 100% sure of, even after looking at hundreds of website. V=sq(watts * impedance). Is it "max" watt, continous watt or just about watts ? So i settled for what Pioneer(premier) say my amp is giving out in continous.( 14.4v, 1x600 W ( 100Hz, 2Ohm ) After calculating what voltage my amps should give out, V=sq(watts * impedance)I came to conclusion that it should be 34,6V. So i unhooked my speakers, put my stereo to about 3/4 of volume, all EQ settings etc. to flat/zero, 50Hz -0db testtone on repeat, all good to set it. To my surprise i couldn't reach the volt i was aiming for. I got to 26,7V at max. Clearly there have got to be something wrong. I've gone over all the settings, tried with 2 different testtones, and still i cant go above 27V on my DMM. Is there anyone who can please tell me whats wrong, what I'm doing wrong, without laughing at me too much ? Best regards, Anders Mercedes CLK 200 Kompressor -01 - Pioneer (Premier ) / Monster Cable DEH-P9800BT, GM-5200T, (2x)PRS-1000D, TS-E176C,TS-E1076, (2x)TS-W3004SPL,
bennett15 Posted June 9, 2010 Report Posted June 9, 2010 what amp are you using make sure your calculating at for the proper ohm loads and if still cannot reach the proper voltage with gain use a bit of bass boost to increase it if you have to use more then id say 1/4 bass boost time for a new amp. be clipping the shit out of it other wise 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
Botev12 Posted June 11, 2010 Author Report Posted June 11, 2010 what amp are you using make sure your calculating at for the proper ohm loads and if still cannot reach the proper voltage with gain use a bit of bass boost to increase it if you have to use more then id say 1/4 bass boost time for a new amp. be clipping the shit out of it other wise Ive Calculated so many times now that im certain of it. My subs get 1 amp each, dual 4 ohm vc parallel to 2 ohm. Ive tried uping up the hz, but using the bass boost is not something i want to use. Maybe a new amp like u say. Might it be something with my battery? Its not been good the last few months, and ive been looking for a new one. But so far i haven't been able to find XS Power dealers in europe. Today i couldnt start my car, even thouhg theres power on my it. Might be going dead, broken cell or something. Mercedes CLK 200 Kompressor -01 - Pioneer (Premier ) / Monster Cable DEH-P9800BT, GM-5200T, (2x)PRS-1000D, TS-E176C,TS-E1076, (2x)TS-W3004SPL,
bigredishott Posted June 11, 2010 Report Posted June 11, 2010 I think if your batt is that bad, you may have answered your own question. Alpine CDA-9847 HU F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels R Highs Infinity Ref. 9622i powered by HU 3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
