Whats up guys. i have a JVC EXAD KW-AVX800 i want to sell. but there is a problem with it. Somebody tried to steal this out of my car and in the process they kind of broke the folding mechanism. The screen still tilts all the way up and down but for some reason when i press the eject button, the screen goes all the way down then comes back to somewhere in the middle and gets stuck, but all you have to do is press the reset button and it will reset itself. they also broke two of the three mounting holes on the mounting sleeve so you'll probly want to order one of those to unless you can make one yourself.
i called a JVC repair shop and they said more than likely it was that the folding mechanism's timing was off.
the DVD/CD drive still works, i know cause there is a DVD full of music that has been stuck in there since the failed robbery attempt, but i got around this by using a 4gig flash drive on the USB connection, holds a very large amount of songs. ill throw that in for an extra ten bucks if you want it.
the screen itself still works great, very bright, but if you dont like it bright it has a dimmer setting, which can also be scheduled to the time. a way to get around the indash not bieng able to accept DVDs would be to connect an external dvd player to it and im sure it will work fine.
its got like 12 or so different color settings and about 4 different display styles i liked to mix em up every once in a while.
it also has a pretty decent 7band integrated equalizer, with three programmable user settings, along with about ten pre-sets
5.1 Dolby Digital
5volt line/Subwoofer output level
video in and out
also has a SD card slot.
im wanting to get 200+shipping for it, but we'll see how yall feel about that,
ok so thats about it, if you got any questions ask away.
IMG_8483.jpg?t=1276060067
IMG_8486.jpg?t=1276060067
IMG_8494.jpg?t=1276060067
IMG_8488.jpg?t=1276060067
9515g
xa-3000s
This topic is now closed to further replies.
