Ive already got a set of cerwin vega comps, they are like a month old. I can't spend that kind of money right now. How ever today im going to peel n seal my rear doors around and behind the speaker, get rid of the little bit of rattle and hopefully make it better.
you ever use peel and seal before?
I have...
Theres a few words of advice I have if you haven't before... and no, it's not "Don't use it" srsly... I have plans that make it work a lil better in my opinion.
| S-10 | 4.5^3 ft | 33Hz | SAE-1000D @ 1 Ohm | 2 SA-12s |
SPL: 143.7 Sealed | 153.4 Port Wars
Yeah Ive used it before, I just finished doing the rear doors. I did a few inches around the speaker and about a foot and a half squared behind the speaker. I cleaned both surfaces with windex to get all the major dirt and shit off then wipped everything down with rubbing alcohol. Got rid of the small rattles I have in the rear door and the bassy notes coming from the rears sounds better. Later in the week i will do my front door when I have some time. EDIT: forgot to add this, i did one layer around the speaker and 4 layers behind the speaker, just because I had it lol
Edited by Tebo
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
