VDubJake Posted June 15, 2010 Report Posted June 15, 2010 Hey im new to car audio and this is the first time i have run into this. So i have a basic system in my 2000 Jetta its a 1000 watt kenwood 2 channel amp running a 12 diamond m6 , running at 2ohm. The amp gets extremely hot and fast and will go in to a protect mode, and wont do anything for easily 12 hours regardless if i disconnect all power. I was thinking its a bad ground but I'm unsure, any input and advice is appreciated. Thanks in advance. Quote
Guest Posted June 15, 2010 Report Posted June 15, 2010 if its 2 ohms bridged, then theres your problem. you're overloading the amp. if not, then your gain is most likely cranked hella up. Quote
VDubJake Posted June 15, 2010 Author Report Posted June 15, 2010 no not bridged and gain is only about half Quote
Guest Posted June 15, 2010 Report Posted June 15, 2010 gain at half could mean you're not clipping or you're clipping the living shit out of your amp. doesnt mean anything unless you actually tuned the gains with an oscilloscope or DMM. its a kenwood and like all their amps are Notorious B.I.G's for overheating. Quote
VDubJake Posted June 15, 2010 Author Report Posted June 15, 2010 what places can tune my gains for me Quote
Guest Posted June 15, 2010 Report Posted June 15, 2010 yourself. look in the electrical section or the amp section (i forget which, or someone can link with a picture to that volt chart with the instructions) Quote
rizzy71 Posted June 15, 2010 Report Posted June 15, 2010 Quote BRENT1997 GMC Yukon1-DC xl18"Stetsom 2K5E3-Kinetik HC1800's 1967 Pontiac GTO
VDubJake Posted June 15, 2010 Author Report Posted June 15, 2010 Sweet thanks everyone ill be setting the gain first thing tomorrow. Quote
