found the problem.. i bought a dmm and checked the terminals and it was reading 2.2ohm so i was like wtf and checked and when i pulled up the sub a wire just fell out.. on the right one... only one coil was hooked up...
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
and i checked the coils on the sub and it read 4.5ish each so they aint blown thank god
im guessing it said 2.2ohms at the terminal cuz only one sub was wired in parallel and the other coil was in parallel but the other coil wasnt :'( oh well im about to fix it and hopefully that was the problem
