Speakers for Towers
I am looking for some good speakers for a set of speaker pillars. I would like one subwoofer (an 8 or 10), two mid range speakers (oen slightly bigger that the other EX: 5.25" and 6.5"), and two tweeters. I would like them made for car audio. The reason is that car audio is cheaper and normally looks better. Also, I want both speakers and the tweeters to match. The sub should look similar, but doesn't have to eb exact. I would also like to know hwo to make the proper crossovers... The sub would handle semi-lows (I will have a subwoofer for low bass), the bigger mid range to handle the lower mids, the smaller mid to handle the higher mids, and the tweeters obviously to do the highs. Please resommend some speakers for me to consider...
Oh, I forgot a budget... I would say about $100 for one pillar...
Dude check out
www.madisound.com
www.partsexpress.com
The most expensive part will be the cross overs
The mids, if you go Silver Flute, they are good for the price, tweeters, hell, I have a bunch of great 1" Dayton tweeters, neo, silk dome, rear mount- flush front
Sure, let's just throw as many drivers as we can into the same passband, let's not care how it sounds but how it looks and let's make them match brands regardless of specifications.
Derp.
Aim to have every speaker identical instead of a different design for front fill, rear fill and centre fill. Marketing bullshit counts for zero here, a difference in design between loudspeakers results in audiological artifacts. Also aim to have every loudspeaker faithfully reproduce as much as possible as sensitive as possible with a flat a frequency response as possible.
Just a heads up; Every time, and I mean EVERY time you add another driver into a frequency divider network, you degrade your phase coherency, your group delay and often your frequency response. The more drivers handling different frequency ranges you have, the further off you are (generally) from the goal of true Point Source.
Try the Vifa D27TG35-06 high frequency driver and the Peerless PAE BC14SG08 Midrange. Great combination in a two way system. If you look at http://www.theloudspeakerkit.com/ they have a design called the F5 (Fullrange, 5") that uses these drivers. Fantastic full range response resonant to below 50Hz.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
