Between front battery/alternator to rear batteries.
so they just connect all the batteries to each other?  I see that Steve does that, but I don't want my starter battery to die out or drain.  I want to isolate it as much as I can, plus I don't want my lights to dim.  Just want a safe efficient way.  Thanks for your reply.
the safest way to go is with an isolator. It will allow you to play your system with the vehicle off and there are times when the second battery will drain down the main battery because it's recharging itself.  As far as grounds I would run a ground to chasis and a ground (or two) directly to battery
  • Who's Online   0 Members, 0 Anonymous, 1255 Guests (See full list)
