uhoh_45 Posted June 21, 2010 Report Posted June 21, 2010 the other day i went to my van (93 astro) to rewire the power inverter and i realized that the washer arm on the steering column is busted and now i cant wash my windows i figured i would just add a push button switch to turn on the washer fluid found the wire going into the vehicle but once inside the cab i cant seem to locate it so i was wondering if anyone knows which wires leading from the steering column activates the washer fluid (its a pink wire from fuse box to the pump) nvm i decided to do something else which will work just as well R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
