I want to wire two subs. Are there any advantages to using a 2 channel amp for two subs instead of a mono channel for two subs? Also, what exactly is the difference between multi-channel amps and mono channels, other than the number?
EDIT: If it matters, Ill be using DVC 2 ohm subs.
mono amp i believe refers to the way the sound is present rather than the number of channels, such as stereo and mono sound
my mono amp had inputs for 2 separate speakers or in other words, 2 pos. inputs and 2 neg. inputs
i believe mono amps at least class d ones, do not run as hot, and do not need as much power to do the same thing as a multi-channel amp, also i believe its more efficient as well
im new to the audio stuff but this is what ive gotten from doing various research or at least i think this is along the lines of what your asking
Reasons being as to why it is more efficient. Efficiency is the key here. A class d mono-block amplifier in 99% of cases require less current to make power. Hence efficiency.
Moral of the story, read your brains out here. Understand ohm loads!!!!! And go from there. But... if this is strictly a subwoofer application amplifier, then go class-d mono-block, no doubt. :good:
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
  • Who's Online   0 Members, 0 Anonymous, 1803 Guests (See full list)
