18inchjeepin Posted June 28, 2010 Report Posted June 28, 2010 * soundstream xxx-6500 Specs: XXX-6500D Channels 1 ch. Class D RMS Power @ 2 Ohm, 14.4V 3,300 RMS Power @ 1 Ohm, 14.4V 5,300 RMS Power @ 1 Ohm, 16V 6,500 Total Harmonic Distortion 5.00% Frequency Response 15-150Hz Signal-to-Noise Ratio 80dB Damping Factor 350 Signal Voltage 500mV-10V Potential Current Draw 460A Dimensions: 2.625"h x 11.375"w x 25.75"L Low Pass Filter 18dB, 50-150Hz Bass Boost 0-18dB, 45Hz Subsonic Filter 18dB, 15-40Hz 18dB, 15-40Hz Phase Control 0-180º HIGH QUALITY SCREW DOWN TERMINALS RCA OUTPUTS FOR EASY MULTI AMP SYSTEM EXPANSION 0 GAUGE POWER AND GROUND TERMINALS Stylish New Exterior Finish! * Gunmetal finish w/ brushed accents * Non-regulated mosfet pwm power supply * Three-way protection circuitry (thermal, short, * impedance) * Twin stack technology TM(strap amps together * for double power) * Delayed on/off circuit * Variable low pass crossovers * Variable bass boost * Variable subsonic filter * 180 O phase control * Pre-amp outputs * Dash mount remote gain control * Direct wire 0 ga. Power, 4 ga. Speaker terminals Description/Condition: used but 8.5 out of 10 for normal scratches still in my car, and did a 155.1 db 2 weeks ago Price: : $650 shipped each sorry no trades * 2x 8" flaired aero ports Specs: 21" long flaired ports made by amartin_72 a total of 6 peices make these 2 flairs, so 1 flair is 1 of each peice (2) 12" long pieces (2) 5" long inner flairs (2) 6" long outer flairs Description/Condition: only used 1, but the paint didnt stick well Price: : $80 shipped for both $45 shipped each * SPL Cell C115 group 31 drycell battery Spec: Height: 8.125" w/o terminals - 9" w/ terminals Width: 13" Depth: 6.625" Weight: 71 lbs. 115 AH Description/Condition: equal if not better than kinetics, sits at 13v aprox 2 years old sits on float charge in my garage Price: : $170 shipped O.B.O. *4 coils, all 4 layer flat wound used 2 2-layer round wound brand new 3 dustcaps new and used 1 15" cone and surround Specs: from left to right was a MT D1, 3" ID 3.375" OD 2" ww 4.6" former D1, 3" ID 3.25" OD 2.25" ww 3.625" former D1, 3" ID 3.25" OD 2.25" ww 4.125" former D1.5, 3" ID 3.1875" OD 2.25" ww 4.125" former D0.6, 3" ID 3.25" OD 2.25" WW 4.125" former 3 dust caps 5 1/4" Description/Condition: slightly used and been in acetone to get glue off 2 2-layer round wound brand new 2 used dustcaps, 1 new 15" cone, has a tear becuase some thing got stuck on it, but its just the top there and should be able to glue back down Price: : 4 used coils - $20 each shipped 2 new coils - $40 each 3 dustcaps - $10 each shipped 15" cone - $15 shipped O.B.O. will do combo deals trades - I need skinnier coils and 8" spiders HHR (2) 15 DC Soundlab Lvl4XL SPL's (1) Soundstream XXX-15000D (9) XS Power D1000's XS Power - Soundstream SS N/W 155.1 db and climbing
Craig28 Posted June 28, 2010 Report Posted June 28, 2010 dang no trades. what are those ports tuned to? TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
18inchjeepin Posted June 28, 2010 Author Report Posted June 28, 2010 ya I have an expensive purchase ahead and need cash tuning would depend on how many cubic ft. the box is HHR (2) 15 DC Soundlab Lvl4XL SPL's (1) Soundstream XXX-15000D (9) XS Power D1000's XS Power - Soundstream SS N/W 155.1 db and climbing
Craig28 Posted June 28, 2010 Report Posted June 28, 2010 ya I have an expensive purchase ahead and need cash tuning would depend on how many cubic ft. the box is im planning on building another 5 cube box TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
18inchjeepin Posted June 28, 2010 Author Report Posted June 28, 2010 im planning on building another 5 cube box can go here and its a great tool http://psp-inc.com/tools.html HHR (2) 15 DC Soundlab Lvl4XL SPL's (1) Soundstream XXX-15000D (9) XS Power D1000's XS Power - Soundstream SS N/W 155.1 db and climbing
Craig28 Posted June 29, 2010 Report Posted June 29, 2010 those are 2 inches wide right? it says if i wanted to tune it to 28 hz it would need to be like 3.5 inches of flared port. would i just cut it then? TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
cnate777 Posted June 29, 2010 Report Posted June 29, 2010 I have personally heard this HHR it is loud I believe mid 150's no wall.....good luck with the sale..... Rockford Fosgate Sundown Audio DC Power Inc XS Autometer Pioneer
18inchjeepin Posted June 29, 2010 Author Report Posted June 29, 2010 those are 2 inches wide right? it says if i wanted to tune it to 28 hz it would need to be like 3.5 inches of flared port. would i just cut it then? these are 8" wide, my math would be over 24" long if you wanted 28 hz I have personally heard this HHR it is loud I believe mid 150's no wall.....good luck with the sale..... thanks ya did a 155.1 2 weeks ago HHR (2) 15 DC Soundlab Lvl4XL SPL's (1) Soundstream XXX-15000D (9) XS Power D1000's XS Power - Soundstream SS N/W 155.1 db and climbing
Craig28 Posted June 29, 2010 Report Posted June 29, 2010 these are 8" wide, my math would be over 24" long if you wanted 28 hz thanks ya did a 155.1 2 weeks ago oh i was a little confused but alright. TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
Craig28 Posted June 29, 2010 Report Posted June 29, 2010 i just plugged it into that psp thing and if they are both 21 inches total it would tune a 5.5 cube box pretty much the same lol TEAM DC Everything is a 150 on th earometer Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw. Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss. AlphaDamp CLD Mat - Get more sound deadening using less sound deadener
