somerandomguy Posted June 30, 2010 Report Posted June 30, 2010 (edited) Isn't it still under warranty? TBH, if it's not under warranty and it's going to cost more than like say.. $50 (or more than you just have sitting around) then why get it fixed, is it THAT big of a problem? Edited June 30, 2010 by somerandomguy Quote
dyeagain15 Posted June 30, 2010 Report Posted June 30, 2010 Just to clarify, A/C works good when shes is cruising at 50+mph but does not blow cold when stopped at a red light for a while? I would check and make sure the radiator fan is coming on when you select the a/c to be on when at idle sitting in park. IF its not, it should to keep a/c system pressures low in their operating range. Otherwise pressures will be too high and the pressure transducers will turn off a/c operation until pressures drop. When traveling above 40mph the fan does not need to operate to keep a/c system pressures down as much as airflow through the grille should be enough for that. i second that, just worked on a lab car the other day and that was the problem, turned out to be a fuse and a relay, be sure to check those Quote My F-150 Build (So Far) 2 DC L3 10's Kenwood KDC-X794 (4) Selenium ST200 (Highs) (2) RE X8 (Mids) Sundown Sub/Mid/High Amps Shuriken Batteries Knu Wiring My Feedback Thread
