Kenwood x693 in protect mode?
I was demoing my system, and after I was done I turned it down, and some time in between that it started saying protect mode. I don't know why it is doing this, I pressed the reset button and it did nothing.
Does anyone know what this could be? I'm thinking its a short probably with my speakers somewhere....
Edited by rumproast789
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
bump
do you have a DMM? if so, test each speaker lead going to the HU to check the ohm load, i think if it is disconnected it wont show, and if its grounding out you might get some crazy result.
Edited by dugee81
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
It seemed fine at the crossover, Should I try it at the headunit harness?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
I have same headunit. Unplug harness, or battery and put it back. See if that works.
I went over every connection basically, redid it all. and Yeah, I believe unplugging the harness worked. Thanks guys
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
  • Who's Online   1 Member, 0 Anonymous, 2169 Guests (See full list)
