Enough for 1500?
Alright guys heres what im planning, dc level on 1500w at 1ohm from the powerbass axa1500.1 my 4 channel is run at 2 ohms for shits an giggles 160 at 2 and 80 at 4. I have a 2008 pontiac vibe with the stock 80 amp alternator, the big 3 done correctly in 1/0 gauge. I will be replacing the stock battery with either xs power(not sure which) or a kinetic 1200 or 1400 i think the 1400 may be to tall to fit my car. Will that be enough for 1500w + my 4 channel? If not I have plenty of room under my passenger seat to add a kinetic hc600 and maybe even an hc800 if i use 1/2inch mdf for the support. Also If i run the battery under the passenger seat it will have a run of pos and neg to the front batt, then a run of pos and neg to a neg distro and pos distro all in 1/0
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
  • Who's Online   1 Member, 0 Anonymous, 1311 Guests (See full list)
