whats better a highoutput altanator or an extra battery my sub cuts out when i hit the bass knob and i cant turn the controls up with out it cuttin out? any ideas on cheap high out pu t alts and cheap bats?
91 cadillac fleetwood and 94 deville
-1 15 d4 orion h.c.c.a 4.1 cubes 32 hz
-1 2500.1 kicker zx
-street wires 0 gauge
A HO alt will help you more then a bat.
But it costs more, but in the long run a alt is a smarter idea. :drinks:
200+ amp DC, Iraggi, Mechman is gonna run you well over $350 but best bet is to contact them. You could get a "cheaper" HO alt from powerbastards or some other companies. Then again, I've heard good and bad about all HO Alt companies so maybe it's hit or miss...
you have a 15.4 and a 2500.1, youre not getting the full 2500. maybe like 1700 or whatever the specs are at 2ohm. i would look into getting a larger power wire and making sure your grounds are solid, sanded down to the bare metal for the best connection possible. other than that, yes i agree with the others. look into a high output alternator. i got mine from excessive amperage but others prefer DC, Mechman, or Irragi.
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
does it cut out cuz of voltage, wrong impedance, or bad ground. or do you know for sure? whats your setup?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
as far as alts go u get what u pay for. if u want a good alt that does its job correctly u are gonna pay
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
WORD!
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
