Maybe I'm stupid, but I fuse for the size of wire at the battery. 120 amp fuse or so at battery in ur fuse holder. Then ur fuses in ur amp protect it. U don't want to put a smaller size at the battery than u have at the amp. Like feeding a fire hose with a straw. U limit the end result.
Correct but the wire has to be able to handle the current aswell, Never fuse over what the wire can handle.
To the OP, Check your coils with a DMM and see what they read, sounds to me like the coil on the "blown" one came un-coiled.
Car - 99 Neon Sport
Batt - 1 Redtop up front On 200A Excessive Amperage alt
Sub - 2 12" Kicker L7's in ~2 cuft @ 36hz each on a Xtant X1001 @ 1 ohm
Front Highs/Mids - JVC CS-FS6 and Infinity 6022i on Xtant A2002
Rear Highs/Mids - None
HU - Pioneer DEH-P8600MP
1/0 wire ran thru entire car aswell as big3
DB - 144.5 @ Dash.
fuse holders usually melt because the fuse gets so hot it melts the plastic casing. this can be caused by running rated power, or close to, through a fuse. example: pulling 50 amps of current through a 50 amp fuse. i hope you put a fuse in the fuse holder that matches the size of the total fuse amount on the amp.
either its that that caused the melting, or a short on the power wire SOMEWHERE along the run of wire.
edit: jl_audio reminded me of something. if the wire isnt tightened down STRONG on the fuse holder on both ends, resistance will cause the wire to heat up alot.
Totally agree :good:
Headunit->kdx-493
memphis mojo mc2000d modded.
Stinger Cables 1/0
soundstream reference r1-15(can get nasty)
hifonics zxi6.5 components
Powered by pioneer 760watt (set low)
I need to figure out whats going on. If the fuse holder melts would that cause a sub to blow? I think I am going to replace all my wiring for my amp and subs. And replace my blow sub............
