theBroken Posted July 7, 2010 Report Posted July 7, 2010 I already got a great ground for my amps. I got a block bolted to a flat body panel that I sanded down to bear metal. Now I'm adding a second battery and a second winch in the rear. Now here comes the noob question of the day. With the battery in the rear can I hook it up like a amp where I just find ground in the rear and then run the power up to the battery or do I have to run both the power and negative from the battery to the rear battery. Same question with the winch. It's just a electric motor, can I run 1 wire up to the power in the battery and a negative to a ground in the rear or do I have to run both wires (positive and negative) to the front battery.
tomypg Posted July 7, 2010 Report Posted July 7, 2010 You can just ground to the body. 1988 Honda City E Big 3 in 1/0 Venom 6x9 Venom 6.5 Components Response 4x100 midz and highs amp Fusion NV 2500.1: STOLEN 2 x 12 inch fusion nv subs 10 inch 5 doller subs in my doors PM me if you want help with electrical
