You shoul turn everything off and disconect your subs from the amp and conect your DMM to each sub separately thats how i do it. And has worked for me.
You should turn everything off and disconect your subs from the amp and conect your DMM to each sub separately thats how i do it. And has worked for me.
Thanks to both of you! Got a reading from 1.6-2.4 ohms on the amp.
Now I heard you can adjust your gain using a DMM to check for clipping? How would I go about doing that?
I've been triying to find a step by step instructions cause i want to learn exactly how to do it with a DMM if someone could help us with this we will apreciate it.
There's an entire thread on that... or you can google "properly set your amplifier gain" because there is a test tone you are supposed to play... IF you have a good ear... you can listed for it... (I know people are gonna argue with that one) but... yes you can... for your setup I think just going to the point that the bass starts to loose power or starts distorting, back it down a notch... It's not SUPER accurate... but will always get you in the safe zone...
  • Who's Online   1 Member, 0 Anonymous, 747 Guests (See full list)
