audioinnovationsfl Posted July 13, 2010 Report Posted July 13, 2010 Hello i have a 2007 scion tc kenwood 945bt, hifonics 1200, hifonics 150x 4 4chan , morel tempo front componets and rear componets , also 2 12 inch Ascendant Audio aresnal series subwoofers wired to 1 ohm all rockford wire and so forth ok i bought a batcap 400 today since my lights were dimming out pretty bad i get out the batcap out of the box and i read the instructions and it say do not ground to vehicle ground and it says ground to the battery which to me makes no sense , since the battery is grounded to the chasis and the motor grounded to the chassis. so if anyone knows why or what the advantage of grounding to the battery would be just want to know before i take my car all apart and run another 4 ga wire to the rear for the bat cap , i dont know if ths makes any sense but maybe some one will know what i am talking about thanks !!
J00bles Posted July 13, 2010 Report Posted July 13, 2010 Hello i have a 2007 scion tc kenwood 945bt, hifonics 1200, hifonics 150x 4 4chan , morel tempo front componets and rear componets , also 2 12 inch Ascendant Audio aresnal series subwoofers wired to 1 ohm all rockford wire and so forth ok i bought a batcap 400 today since my lights were dimming out pretty bad i get out the batcap out of the box and i read the instructions and it say do not ground to vehicle ground and it says ground to the battery which to me makes no sense , since the battery is grounded to the chasis and the motor grounded to the chassis. so if anyone knows why or what the advantage of grounding to the battery would be just want to know before i take my car all apart and run another 4 ga wire to the rear for the bat cap , i dont know if ths makes any sense but maybe some one will know what i am talking about thanks !! no real benefit of doing a (-) between batteries like that. you can either ground to the frame, or run another wire to the battery. 8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee Click to see J00bles' Youtube Channel
k3n12ock Posted July 13, 2010 Report Posted July 13, 2010 Better ground/voltage from the battery as compared to the body/frame of a car. And you should upgrade to some 0/1 gauge wire bro. Also, you don't REALLY have to add a negative run from front to back but it helps. 05 xB - (2) EVIL 18s - (2) BC3500s - NO WALL Channel 1: http://www.youtube.com/k3n12ock Channel 2: http://www.youtube.com/MrK3n12ock2
Ace302 Posted July 13, 2010 Report Posted July 13, 2010 I just grounded mine to the rear chassis, I believe your just not supposed to use the same ground as something else. My batcap has worked great since, just make sure you sand off the paint at the grounding point.
audioinnovationsfl Posted July 13, 2010 Author Report Posted July 13, 2010 no real benefit of doing a (-) between batteries like that. you can either ground to the frame, or run another wire to the battery. see thats what ive been doing for years just grounding to the frame like batteries and caps but i read these bat cap instructions and it said not too which really gets too me
audioinnovationsfl Posted July 13, 2010 Author Report Posted July 13, 2010 yes i have 2 4 ga wires running from the front , and also i always sand the paint off the frame for my grounds the only big positive i could see with running the bat cap neg wire up front would be trying to kill any ground loop noise so everything would exactly be grounded out at the same place.
