I'm planning on running a few kinetik 2400s in the back but for under the hood I'm not sure. I've seen 1400,1800 and heard 2000 fit with nothing moved and seen steve meade has the 3100 power master but I was thinking about putting the matching 2400 in the front?? And was wonder if the weather up here in michigan would get to cold for it? Thanks
2 18" fi btls
2 sprinter batts 165ah
1 cresenscdo 3k
1 mechman 270a
1 kinetik 2000 under hood
I was trying to help him with this. Ive heard things about kinetics not liking the extreme cold we get here and then not start the truck.
Team DC!
2005 F150 | Pioneer | Infinity Kappa 6x8's | MTX 3404 4 Channel | Q Logic Kicks | KNU | DC | AQ |
1998 Taurus | Alpine | Punch 5x7's | Rockford Fosgate | MTX | KNU |
ive got an 1800 under my hood...had it the last three winters, no problems. got two buddies with 1800s under theirs also no problems...and were up here in northern michigan.
<u>99 Jimmy SLT 4WD</u>
Systemless.
<u>99 Grand Prix GTP</u>
DC XL 12 on 1.5k tuned lowwwwww.
Sounds good what do you think about the 2000 or maybe even the 2400 in a 04 denali
2 18" fi btls
1 cresenscdo 3k
1 mechman 270a
the 2400 will fit but like steve you will have to move the computer and remove the bracing. If I remember right the 2400 and 3100 are the same size. A 2000 would fit easier tho. I am about to put two up front in my 01 burban.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
passenger side fender well by the firewall and drivers side fender well by the headlight housing
those are the 2 battery locations
you'll have to notch the lip just wide enough for the battery to fit and fold it down
then move the PCM over a little bit but it will fit
Steve showed me how to get the D3100 in a couple days ago when I was at his shop
its fairly simple
Wouldnt be thehoe92 without teh purple
Ok not bad. If I went with 2 2000 I wouldn't have to cut right?
2 18" fi btls
1 cresenscdo 3k
1 mechman 270a
  • Who's Online   0 Members, 0 Anonymous, 2007 Guests (See full list)
