TNtrailblazer Posted July 17, 2010 Report Posted July 17, 2010 I have a Rockford Fosgate T1500.1bd for now and was ordering some FI bl 12s. Should I get the dual 1ohm or dual 2ohm option on them?
chevyman217 Posted July 17, 2010 Report Posted July 17, 2010 I have a Rockford Fosgate T1500.1bd for now and was ordering some FI bl 12s. Should I get the dual 1ohm or dual 2ohm option on them? How many Fi bl's if 2 then dual 2 ohms, which when in parallel is 1 ohm before sub woofer box rise. Never mind Welcome to SMD! BTW Some people could care less about who the genius is that is making the product... They just want to get it cheap and say "derrrr, look at teh pretty lights in muh dash!" Because audio is a lifestyle not a hobby. Things that I am allergic too.... Haters Bitch Notes
JBurt09 Posted July 17, 2010 Report Posted July 17, 2010 How many Fi bl's if 2 then dual 2 ohms, which when in parallel is 1 ohm before sub woofer box rise. Welcome to SMD! BTW That is per woofer, if he was only running one.If he got two dual 2 ohm sub, wired each in parallel for 1 ohm, them wired them to the amp, which would parallel them behind the input on the board, he would end up with a .5 ohm load. If you wanted to get technical, the dual 2 ohm BLs are actually 1.4 ohms, so when wired in parallel would be .7 ohms, and then paralleled at the amp would be .35 ohms, hardly what Rockford would recommend for their amps. If you are wanting to run 2 subs off of the same amp, run with the dual 1 ohm versions.They can be wired in series for 2 ohms per sub (1.4 in reality) and then paralleled at the amp for 1 ohm (.7) before rise.
chevyman217 Posted July 17, 2010 Report Posted July 17, 2010 That is per woofer, if he was only running one.If he got two dual 2 ohm sub, wired each in parallel for 1 ohm, them wired them to the amp, which would parallel them behind the input on the board, he would end up with a .5 ohm load. If you wanted to get technical, the dual 2 ohm BLs are actually 1.4 ohms, so when wired in parallel would be .7 ohms, and then paralleled at the amp would be .35 ohms, hardly what Rockford would recommend for their amps. If you are wanting to run 2 subs off of the same amp, run with the dual 1 ohm versions.They can be wired in series for 2 ohms per sub (1.4 in reality) and then paralleled at the amp for 1 ohm (.7) before rise. Damn lol your right. Sorry for the p.o.s post wasn't thinking lol. :noob: Some people could care less about who the genius is that is making the product... They just want to get it cheap and say "derrrr, look at teh pretty lights in muh dash!" Because audio is a lifestyle not a hobby. Things that I am allergic too.... Haters Bitch Notes
