RCA cable making weird noise when touched
okay I have a 15" sub in my trunk, I just added two 10's to sit behind it in their own box. when I try to hook up the second amp I plugged in the first RCA's that go from the amp, then I noticed when I touch the top of the white on it makes this loud buzzing noise and my subs also boom for a second, what's up with this? I don't wanna blow up my car so anyone have any ideas?
2004 Volkswagen GLI
1 10" Skar VVX
^^^ Looking for an amp to run it, Pm me if you have one ^^^
I dont know exactly what its called.. but its perfectly normal.
Its an electrical signal of sorts from your body, just basic interference...
Nothing to worry about though.
Pioneer x930 bt
Rockford t2500 bdcp
18" nightshade v1
DC audio 175.4
RF power T162s up front, infinity 3 way 6x9's in the back (removing rear stage and re-doing doors soon)
3x XS power D2700's
Knukonceptz 0awg all around
I might as well be the first to say this, dont mix sub sizes it will sound like poo........
Unless they are on a different amp and crossed over differently, for example you would have the high pass on the amp to the 15 set at 50Hz, and the lowpass on the 10's set at 50Hz so they dont play the same notes, cause that will most likely end up causing cancellation, so the 15 will handle the bass below 50Hz and the 10's will handle bass above 50Hz.
Just a lil heads up.....
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 1174 Guests (See full list)
