What impedance are you going to be wiring your amps to? And what's the RMS at that ohm?
Edit: well assuming you'll being wiring your 1500 @ 1ohm, and the 600 @ 4, you would do watts * ohm (1) = 1500, then find the square root of that which is 38.7 volts AC.
If the 600-4 is 150wrms @ 4ohms, you'll want to do 150 * 4 = 600, and the square root of that is 24.5 volts AC
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Ahhh, ok.... Well I'm actually running the T1500 @ 2ohms (1000Wx1 @ 2ohms) so that would be 1000*2=2000, sqrt(2000)= 44.72V AC. Im running the T600 @ 4ohms (100Wx4 @ 4ohms) so 4*100=400, sqrt(400)= 20V AC. This is correct, right?
Yep, that's correct.
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
yeah, so the formula you were just givin is the "quick way" to do it, with a DMM but its not the best way but it does work, the BEST way to do it is with an oscope but those fuckers are expensive!
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
NO KIDDING!!! I was trying to scoop one of those up on ebay for cheap, and well, they weren't too cheap!!
  • Who's Online   0 Members, 0 Anonymous, 2088 Guests (See full list)
