So I got this double din for my car to give it a stock look but with better features. And I have done all my work before this on my car had 2 previous head units in there no problem. So I hook this all up and bam nothing it has something ive never seen before. It has a ground that u hook to the body and not the other ground. This confuses me ive tried many things checked everything 10x too. Also heres the deck http://www.sonicelectronix.com/item_21600_Eclipse+CD1200G.html
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
so I just leave the original harness ground just danglin?
Edited by marquettefan247
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
gotcha thanks bro ima go try it
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
got it to turn on but not turn off I think its just wiring
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Both power wires hooked up right? Sounds like constant power to both. Does the car keep the radio on til the door opens or anything like that with the stock radio?
no the stock doesent with the key out but i drew a diagram minus the speaker wire of what it looks like.
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I have the chimes in there its a sosche gm2000 in there because with an after market radio it needs it for the doors chimes and shit
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Honestly, I have no experience with that harness. I don't know if the colors match up correctly or whatever. A quick google of the gm2000 didn't help much, some people have this problem, and the only suggestion I saw was to get a new harness. Nobody ever said if it worked or not lol. Maybe somebody more familiar with the setup can help. But you said you've had other aftermarket decks in the car before, right? So it should still work...idk.
