6 15"s on tahoe box design question!!
im wanting to build a wall in my tahoe with 6 15"s. I plan on using the orion xtr's or xtr pro's. they require max 3 cubic foot per sub for vented enclosure by the spec sheet. I will be doing 2 amps for each set of 3 subs. my question is it recommends using round port or vent, but since im doing 6 should i build the box with 1 port for all subs, or 2 ports for each set of 3 or a port for each sub???? if so does anyone have any idea what size port to use?
any help is appreciated!!!
18 cuft with 230-260 sqin of port. 9" wide by 27" high would give you 243. 18" deep would give you a tuning of ~34hz
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • 3 weeks later...
Looks amazing man, really nice job.
I'm not an out of control driver, I'm completely in control.. only sideways..
-Nissan R32GTR running 213KW RB20DET on 14lbs of boost.
-Holden Commodore VY SS UTE running stock.
-Holden Rodeo mini truck project, soon to be running SR20 on 13lbs of boost.
-Landcruiser UTE running 1UZFE v8 11" Lift on 35" MT Classic II's wrapped in Cooper STTs.
^^ and the list goes on..
  • Who's Online   0 Members, 0 Anonymous, 2216 Guests (See full list)
