Jeremy1998 Posted July 28, 2010 Author Report Posted July 28, 2010 Why would you want to do this? I didn't know that you can run 12 volt systems on a 14 volt battery... I guess it's all up to my brother in the end...
EricR Posted July 28, 2010 Report Posted July 28, 2010 Are you serious? http://4xspower.com/ Please ignore the idiot that thinks there are no 14v batts. i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
Cashdollar2009 Posted July 28, 2010 Report Posted July 28, 2010 I didn't know that you can run 12 volt systems on a 14 volt battery... I guess it's all up to my brother in the end... Personally I think you would be better off running a 12V battery on a good charging system than a 14V battery on a so-so charging system. When you turn the car on you will be seeing 14+V with the 12V, in case you are getting confused. On 6/30/2011 at 1:11 AM, 'Ray' said: Acoustical energy is free. Electrical energy is not.
Jeremy1998 Posted July 28, 2010 Author Report Posted July 28, 2010 Personally I think you would be better off running a 12V battery on a good charging system than a 14V battery on a so-so charging system. When you turn the car on you will be seeing 14+V with the 12V, in case you are getting confused. Yepp, I understand... So techincally can the amps run on 16 volts then? As in the 16 volts charging and the 14 volt batteries?
