small problem turning EPIC
So I was playing my music at the averave volume I play when on my way to work and I saw a small cloud of smoke come from under my steering wheel I quickly turned off my music and checked out everything. Couldnt find anything wrong didnt see any burned wires or anything and all my electrical equip still worked even the system. So I went on, about a week later my heater fan started turing off and on, then my system started doing the same now neither come on at all. Here is first steps I took
Checked all fusing
Looked over all grounds
checked all relays
And didnt find a damn thing now im taking more drastic measures here is some pics just got started in search of the problem PLEASE HELP IF YOU CAN
CAR; 88 CRX SI
Im checking all the wiring in the car. I mean all of it.
I had to get another vehicle just for the daily commute to work.
If anyone has any ideas that might make this process faster please I am open to opinions
damn bro idk..
Something caught on fire and you can't find the source of it?
00' Nissan Xterra
Always under construction :]
HU: Pioneer DEH3100-UB
Mids & Highs: Kicker DS Component Set & Crescendo tweeters
Mids & Highs Amp: Rockford 150.2
Subwoofer: 2 DC Audio LV 4 18"s
Subwoofer Amp: Hifonics Brutus 2005d
you been hanging out with jeff and dustin with that green paint? its yellow so it has to be loud.
No not on fire I am guess something just got hot enough to melt some wiring and create a short. Maybe in the big bundles of wire there was some possible rubbing and over 20+ years it finally gave out.
maybe might have to rewire the hole car.. so it doesnt drive? since you said the heat started first i would look into that wiring
Could have shorted and melted the wire..then the exposed wire could have touched another wire that was exposed..or you could had a shorted out fuse. Guess you gotta go through it with a fine tooth comb.
00' Nissan Xterra
Ya no shorted out fuses or relays Im going through everything now and using a dmm to test everything I can I will post more pics of what I find until the problem is solved
  • Who's Online   0 Members, 0 Anonymous, 1341 Guests (See full list)
