NDAudio Posted August 1, 2010 Report Posted August 1, 2010 Hey guys I have two T5 soundsteams 12 inch with 2 sound storm amps one 2500 and one 1500 nd I need to bridge them we tried but all we got they just kept arching please help I need this for a competetion. Either messege me on here or messege me on my email at [email protected]
JEMT8 Posted August 1, 2010 Report Posted August 1, 2010 Hey guys I have two T5 soundsteams 12 inch with 2 sound storm amps one 2500 and one 1500 nd I need to bridge them we tried but all we got they just kept arching please help I need this for a competetion. Either messege me on here or messege me on my email at [email protected] Are you trying to bridge both amps together like master/slave setup? formerly known as Jaylor Swift
gumbysmoke Posted August 1, 2010 Report Posted August 1, 2010 if you're strapping them here's a little step-by-step i copied from another forum a while back If you strap the amps you will have complete control of all the drivers from one amp (master). I would strap them so you do not have to try and match the levels by ear.Since you do not have the manual I'll walk you through the process.. Set one amplifier to Master and one to Slave. Connect the RCA cables from the Head unit to the Master amplifier. Use a single RCA cable to jump the two amps (Master/Slave) together (mono connector). Connect the negative slave speaker output to the negative master speaker output. (14 gauge wire or bigger must be used) Use the Positive speaker output on the master as the Positive speaker connection. Use the Positive speaker output from the slave amp as the Negative speaker connection. Connect Power, Ground and Remote turn on to both amps. Turn the settings on the slave amp to 0 and adjust the output from the master amp only. Now you can enjoy! 2001 Oldsmobile Alero 15" Fi BTL firing into cabin sealed from trunk (trunk wall) 8" interchageable flared aeros 4.8ft^3 box tuned to 34hz 2 AQ 1200's strapped (comming soon) Wiper flexage on only 1300 watts.. Link to my build.
