amps shut off then turn on when turned up
i have a problem with my alpine mrp-m1000 amp. when the system has been playing for a while the amp shuts off i think it overheats.its mounted behind fold back seat in a 2002 impala.
the amp is powering a kicker l7 15". i also have an alpine mrp-f300, both amps are powerd by one main power 1 guage wire. the power wire is split to amps at the capaciter out put. Is this a bad design in my part
SOunds like an overheating problem, try getting a cooling fan, or just moving it to a different spot with more air circulation
Can you fold the seat down? Maybe that and have your windows open for air circulation
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
Bigger wire can not allways help heating problems. The problem happens when drawing lots of current and bigger wire can hold more current
And when I say wire I mean power and ground also voltage drop can cause this
  • Who's Online   0 Members, 0 Anonymous, 2453 Guests (See full list)
