the port can just go all across the top of the enclose (end to end), 3.5 inches tall (which will give me about 18^2 inches per cube) and it will be 35" long, giving me a tuning fq around 33 HZ
How wide is the box? Try to keep a 9:1 port ratio or lower. If the port is gonna be 3.5" tall, it shouldn't be more than 31.5" wide. Might run into port noise if its over a 9:1, but in the back of an SUV, it probably wont matter much.
Eric is right though, a 90* angle at the "mouth" of the port is bad. Do the lower port, then go up the back wall if necessary
the plan for the port was 38.5" wide
Edited by Tek
and the middle sub won't have a loading problem?
In the first drawing you will have differential sub loading. Meaning the one closer to the port will move alot more than the other two. I learned this from experience and it doesn't work. Due to the sloped hatch in the aztac I would do both sub and port's up. Place the port on the drivers side.
TEAM FLEX ISSUES, TEAM DC AUDIO
2010 California State Finals Champion MECA AS2
2011 California State Champion Meca S2
2011 California State Record holder Meca S2
2012 Meca Mod 4 class 152.5 and rising
1. I already canceled out the idea of that first design
2. There is 3 subs, not two
3. The design I changed to IS port up subs up
4. Now, the only thing I am concerned with is port noise coming from a 38.5 X 3.5 port if there is any at all
Edited by Tek
Ok I promise Ill think about it if you can tell me if those dimensions will give me port noise
might be some port noise since its long & narrow, if there is just take a big roundover bit to it :good: .
how many inches of port per cube does that give u?
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
18
