neutman21 Posted August 5, 2010 Author Report Posted August 5, 2010 I did a check on the wires and all of them seem to be tight... Quote THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK… Alpine CDA-9887 Audiocontrol three.1 JL Audio xd400/4 JL Audio C5-570 Components JL Audio C2-570x JL Audio hd750/1 JL Audio 12w6v2 Optima Yellow Top Viper 350hv
Guest Posted August 5, 2010 Report Posted August 5, 2010 you dont need a new alternator. i ran 2 amps (totaling about 1000rms) on a stock 70 amp alternator and the big 3. you do not need one. you will always get dimming even if the voltage drops a tenth of a volt. Quote
neutman21 Posted August 5, 2010 Author Report Posted August 5, 2010 Ok, I am doing about 1150 rms... and the big 3 probably wouldn't fix the problem would it?? Quote THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK… Alpine CDA-9887 Audiocontrol three.1 JL Audio xd400/4 JL Audio C5-570 Components JL Audio C2-570x JL Audio hd750/1 JL Audio 12w6v2 Optima Yellow Top Viper 350hv
dugee81 Posted August 5, 2010 Report Posted August 5, 2010 It definitely wouldn't hurt to do, and doesn't cost much to accomplish Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
neutman21 Posted August 5, 2010 Author Report Posted August 5, 2010 ok. ill give it a try... and is it recommended that i only use 0 gauge? or can I use something smaller? Quote THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK… Alpine CDA-9887 Audiocontrol three.1 JL Audio xd400/4 JL Audio C5-570 Components JL Audio C2-570x JL Audio hd750/1 JL Audio 12w6v2 Optima Yellow Top Viper 350hv
Guest Posted August 5, 2010 Report Posted August 5, 2010 do the big 3 in 1/0 copper wire. and your alternator is most likely like 100-120 amps so you do not need a larger one when mine was fine and it was only a 70. Quote
neutman21 Posted August 5, 2010 Author Report Posted August 5, 2010 Ok, I thought mine was around 75 amps.... Quote THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK… Alpine CDA-9887 Audiocontrol three.1 JL Audio xd400/4 JL Audio C5-570 Components JL Audio C2-570x JL Audio hd750/1 JL Audio 12w6v2 Optima Yellow Top Viper 350hv
dugee81 Posted August 5, 2010 Report Posted August 5, 2010 (edited) I would say 4awg big 3 would suffice Edited August 5, 2010 by dugee81 Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Guest Posted August 5, 2010 Report Posted August 5, 2010 You I would say 4awg big 3 would suffice ...1/0 gauge. no point in having 4 gauge then upgrading later on. its only a few bucks more Quote
dugee81 Posted August 5, 2010 Report Posted August 5, 2010 Valid point good sir Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
