Make sure both subs are inphase. Are they series or parallel?
They are wired in series down 2 one ohm. But for wiring the fuse box should i use the kind that is 2 fuses in one or should i just run 2 separate runs?
what is the coil configuration on your subs? If you are at one ohm, is your amp one ohm stable? when your subs play, do they both play in the same direction?
////Alpine, Eclipse, Load Boss, Pheonix Gold, MB Quart,Digital Desings, Memphis, Stinger, Periphial, MTX, Visualogic
they are dual 4ohms wired down to one ohm, and yes they do play in the same direction
ok so thet are in faze then. is your amp 1 ohm stable?
  • Who's Online   0 Members, 0 Anonymous, 2639 Guests (See full list)
