some might know others may not but i have a Soundstream XTA600.2 and two Kicker Cvr 15's
now wut i plan on doing is bridging the two channels for 1200w max at 4 ohms. im planning on running the subs in a series/parallel setup which makes 4 ohm load which is perfect.
my question is... will the 1200w max go to both subs or will it get cut in half because i have two subs? cause i was told a 1000w mono block amp would be perfect for my subs so i thought this would be great... was i mistaken?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
