2 18" RE xxx + 16 highs... 150db Epic-160
Just finished my build before Carlisle this past weekend and had time to get all the pics sorted and finally a vid, too!
Here's the setup:
2010 Toyota Tundra TRD Rock Warrior Double Cab
-2/0 Power/Ground
-Factory Group 27R battery, 2 Kinetic 1800s, and 1 Kinetic 1400
-Stock 150Amp alt
-Stock Radio
-Audiocontrol Three.1
-Audiocontrol Epic-160
-Crossfire xp6004 powering:
-(2) Beyma cp16 tweeters
-(2 pairs) JL xr csi650 components
-Crescendo 1000.4 powering:
-(4) Beyma 6mi80 6.5's
-(2) Kicker rmb8 8's for midbass
-modded MA hk4000d powering:
-(2) '02 flat-motored RE xxx motors with 18" PSI recones
-11 cubic foot box tuned to 34hz
-22" Ultra Magnus matte black wheels, on 305/45/22 tires.
-15% tint over stock rear
-35% tint on front windows
-yellow lamin-x on fogs
-smoked lamin-x on lower-half of tails
-Hornblasters Shocker 240 train horn kit
Here she is:
Box built, test fitting baskets before building the subs:
Fiberglass in the inside corners for reinforcement:
Fiberglassed speaker/port enclosures on top:
More glass and some bondoglass as well:
Wrapping the top:
Top and front are the same piece of fabric:
Wrapped and ready:
Loom in the top section for all speaker wires:
What the loom houses... wires with male clip connectors to make it easy plug-n-play when the box goes in:
Loom in the back:
Loaded!
All wires loomed/taped/ziptied/organized (these amps are for the highs) Note, the wires hanging from the amp... they're the female counterparts to the wires in the box loom:
How do you put a box this large in??? Easy... an engine hoist and a door off!
In and ready to connect!
and... got the back seat in!
Grillcraft Grill
Tonno Pro Tonneau Cover
Train Horn Pics & Vids:
All the goods:
Getting the bed ready... uh-oh, what are those batteries for???
Decided to keep things in the bed, considering it's rare I end up using the space past the wheel wells. Here's the compressor
Here's the air tank
My buddy Rob blastin' sparks cutting the bracket frame
Rob gettin' his weld on
Close-up of the bracket
Ready to mount
Backside
Clamped and ready to drill some holes
Hardest part of the install... got a bad case of the red face :mad:
And... of course the vids!
Here's a quick honk taken with my girl's digi cam:
Here's a comparison of the stock horn and Shockers taken with my Blackberry (so, not so much quality)
