sYstEm eRRoR Posted August 15, 2010 Report Posted August 15, 2010 Hi All, Newbie here and have a question. If I put 2 jl 12"w6v2 powered by a 1000watt amp, do I need to add an extra battery? 2002 ford taurus Thanks
TeejayBee Posted August 15, 2010 Report Posted August 15, 2010 if you set your gains right i dont think you will need to but if you want one i can sell ya one
Spitfire2k6 Posted August 15, 2010 Report Posted August 15, 2010 Depends on what amp it is, some are under and some are over rated, if its under 1k true rating id say no you'll be fine Live life to the full... Then TURN THAT BITCH UP!
sYstEm eRRoR Posted August 15, 2010 Author Report Posted August 15, 2010 if you set your gains right i dont think you will need to but if you want one i can sell ya one Thanks for the offer TeeJay. I do not want to add a battery. I just want to plug and play. Thanks for the speedy reply
sYstEm eRRoR Posted August 15, 2010 Author Report Posted August 15, 2010 Depends on what amp it is, some are under and some are over rated, if its under 1k true rating id say no you'll be fine Ill try and find out the amp.
TeejayBee Posted August 15, 2010 Report Posted August 15, 2010 yeup i mean mine arnt for sale till sept 5th so if ya change your mind get back to me
King Zick Posted August 17, 2010 Report Posted August 17, 2010 Depends on the car and setup. Usually with the BIG 3 done you won't need another battery or high output alternator. The King.
