XS Power
nathan i know he had some issues with his vcm. i have one on the way for the same yr hoe but with 3 alts. i dont want to run into any problems of course your harnesses are coming for all 3,is it just simple plug an play
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Yes, when you purchase the harnesses for the alts it is just plug and play basically. First thing you need to do is get all three alts working without the VCM hooked up, and then hook up the VCM. You cant use the VCM harness to power the other alternators. The VCM harness will only hook up the alternators to the VCM so it can control the voltage.
