tiptonsrt4 Posted August 23, 2010 Report Posted August 23, 2010 ok so i just orderd a fi ssd12 and im putting it in my 04 neon..would this box be to big for the sub or can i make it smaller..specs. width-34, heigth 15.5, depth 23.5..and will be tuned to 34hz.also i will be using 3/4 mdf..i also used to RE enclosure calculator..but i just want to be sure first sense it will pretty much be my entire trunk space
Guest Posted August 23, 2010 Report Posted August 23, 2010 dont use RE's calculator, its shit. go in the enclosures section of the forum and download Torres' calculator. it MAY be advanced for you but press F1 and you get help, if you have further questions go ahead and ask away on here lol. but go with what fi states, i dont know off the top of my head (and im too lazy to go and look at the moment) but stick within those 2 numbers they give.
tiptonsrt4 Posted August 23, 2010 Author Report Posted August 23, 2010 ok well i used it..and i do not understand it at all...so iv changed the mesurments and the space i can work with is width 34, height 15.5 and depth 11..that should come out to 2.5cuft.and thats the biggest the sub calls for..now can some one plz figure out the port for me and the mesurments for it..the sub calls for 33hz..the calculator wasnt showing me the cuts for the port and i just didnt understand what to do with the ports
BTL FTW Posted August 23, 2010 Report Posted August 23, 2010 dont use RE's calculator, its shit. go in the enclosures section of the forum and download Torres' calculator. it MAY be advanced for you but press F1 and you get help, if you have further questions go ahead and ask away on here lol. but go with what fi states, i dont know off the top of my head (and im too lazy to go and look at the moment) but stick within those 2 numbers they give. what's wrong with the RE calculator? Alpine F1 Status DD CS6.5 x2 Front Stage DD 9512H DD M4a @ 2 ohm DD S2b @ 8 ohm per channel I run high ohn loads for MASSIVE headroom and cleaner SQ 270amp alt D2400 up front D3100 x2 batter in back
bkolfo4 Posted August 23, 2010 Report Posted August 23, 2010 It gets confused on L shaped slots. Calculates the back piece incorrectly. I have also seen Torres have issues. Use them to get started and then check everything and adjust as required. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
