anthonyott99 Posted August 28, 2010 Report Posted August 28, 2010 (edited) Would the PowerBass asa600.2 be a good amp for two 12's that are 350 rms and 1200 watt max ? I think the powerbass amp is 600 bridged at 4 ohms , so it would be 1200 bridged at 2 ohms correct ? and what do yall think of the powerbass amps ? oops shouldve posted in amplifiers, sorry ! Edited August 28, 2010 by anthonyott99 Quote
onelivinlarge Posted August 28, 2010 Report Posted August 28, 2010 Would the PowerBass asa600.2 be a good amp for two 12's that are 350 rms and 1200 watt max ? I think the powerbass amp is 600 bridged at 4 ohms , so it would be 1200 bridged at 2 ohms correct ? and what do yall think of the powerbass amps ? oops shouldve posted in amplifiers, sorry ! NOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! bridged 2 chans r not 2 ohm stable period end of story so no it wont do 1200 it will not do more then 600rms try something more like this http://www.sonicelectronix.com/item_26887_PowerBass+Xtreme+XAX-500D.html or http://www.sonicelectronix.com/item_21955_Kicker+ZX500.1+-10ZX500.1-.html or http://www.sonicelectronix.com/item_27501_Combo-+Rockford+Fosgate+PRIME+R500-1+%2B+Amp+Kit.html or http://www.sonicelectronix.com/item_25750_Rockford+Fosgate+PRIME+R1000-1D.html take your pick since u did not give a price range Quote 1) lookj to left 2) NOTICE BLKUE 3) ME > Y9OU 4) that is all
anthonyott99 Posted August 28, 2010 Author Report Posted August 28, 2010 oh no, cant afford those ! but i have one 600 watt already so still can use the powerbass along with it. Why does the amp say 1200 watts if it isnt 2 ohm stable ?? oh and could only spend like 75 dollars and got the powerbass for 65 bucks ! Quote
onelivinlarge Posted August 28, 2010 Report Posted August 28, 2010 oh no, cant afford those ! but i have one 600 watt already so still can use the powerbass along with it. Why does the amp say 1200 watts if it isnt 2 ohm stable ?? oh and could only spend like 75 dollars and got the powerbass for 65 bucks ! that is 1200 watts max (and thats not a bad deal) u can use the power bass amp just use both chans one for each sub and wire the subs down to 2 ohms and u should get 300 per chan and be good just set gains correctly Quote 1) lookj to left 2) NOTICE BLKUE 3) ME > Y9OU 4) that is all
anthonyott99 Posted August 28, 2010 Author Report Posted August 28, 2010 (edited) Well i know enough to at least know that the powerbass is better than my jvc 600 watt ! may just use one on each sub ? would that work ok or not ? Edited August 28, 2010 by anthonyott99 Quote
anthonyott99 Posted August 28, 2010 Author Report Posted August 28, 2010 Well i know enough to at least know that the powerbass is better than my jvc 600 watt ! may just use one on each sub ? would that work ok or not ? What im tryin to ask is . . . . . would it be better to run my subs off the powerbass vs my 600 watt jvc, or run one sub off each amp ? If the powerbass will provide my subs with a little more thump then i will use my jvc for a component amp. Opinions please ? Quote
