codyb8909 Posted August 29, 2010 Report Posted August 29, 2010 hey whats up...i'm thinking about gettin a pair of Cerwin Vega 154's..SVC 4 ohm 500rms 1000peak Anyone one on here wanna chip in a few words? They any good? They be running off a ZX1000.1 ...... Appreciate it
STEvil Posted August 29, 2010 Report Posted August 29, 2010 250w RMS each will be tons of power, they dont need a lot. I have a 158 that i'm running free-air at the moment as LFE on my home sysetm and it does fairly well. If you built a horn enclosure they would get violent. I want to find 3 more 158's.. edit - they dont do well in small sealed enclosures in trunks. You need a ported enclosure at least. MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
codyb8909 Posted August 29, 2010 Author Report Posted August 29, 2010 250w RMS each will be tons of power, they dont need a lot. I have a 158 that i'm running free-air at the moment as LFE on my home sysetm and it does fairly well. If you built a horn enclosure they would get violent. I want to find 3 more 158's.. edit - they dont do well in small sealed enclosures in trunks. You need a ported enclosure at least.
codyb8909 Posted August 29, 2010 Author Report Posted August 29, 2010 About the VEGA 154...can they be reconed with a STROKER CONE/ and coil...???
STEvil Posted August 30, 2010 Report Posted August 30, 2010 i dont know MickyMcD - "Capable of making some serious trouser flapping volumes at where's-my-testicles frequencies, the Servo-Drives used to be fairly jaw dropping..." Any time you have have a power wire next to your frame put some rubber hosing (or cut up an innertube) around it. The wire is bound to wiggle (due to driving or flex) and the casing will eventually wear through. Hammerdown... 1% no links to outside websites, business related FB/YT pages allowed.
Colin - STAPUFT Posted August 30, 2010 Report Posted August 30, 2010 If you are talking about the ones like are in my sig, just the 15" versions- then i approve. Like STEvil said, they don't need much power because they have such high sensitivity (but up to their limits makes them even louder) and it is all about the enclosure. Big ported or a horn. I think there is someone here on SMD who put one into a Transmission Line and had really good results too. 12 - 12"s in the STAY PUFT 1989 Chevy Astro Build & Comment Log Un-Interrupted Build LogYouTube Channel Chevy Trailblazer 5.1 Dolby Digital DTS Install You have a beard of a mysterious sea captain. I would follow you to hell and back.
