Tell me if this is right/the best way
I have a alpine CDE-102 with 2 sets of 2 volt pre-outs. I want to up the voltage.The plan is to run 2 pairs of RCAs from the HU to the line driver. Next run 2 pairs of RCAs from the front/rear outs to my 4 channel amp powering my mids. I will then run my sub out rca to my sub amp. I have a 2 channel amp for my tweeters so i plan to use the out channels on the 4 channel amp to send the signal to the 2 channel amp? Might be confusing but just tell me if thats good or not.
My 02 Accord Wall Build
2 Sundown Audio Nightshade V1 18s --- 1 SAZ 3500
Sundown Audio 100.4 --- 4 Sundown Audio Neo-Pro 8s
Sundown Audio 125.2 --- 2 Morel MD-12 Tweeters , 2 Selenium ST-200 Tweeters
DC Power 270xp --- 4 XS Power D1200s | 1 D5100R
sure why not? you are basically installing a line driver in between the amp and the headunit
Also, you are dreaming if it is a true 2v out of the Alpine, I do a lot of alpine and anything over 25 on the dial which should be 1.2 volts starts distorting audibly. if you have a scope and access via a test cd, you will see for yourself.
SMD SuperSeller VerifiedJbondoXJames Shields
well even with 2 volts i still wanted more lol. Thanks for letting me know though
  • Who's Online   0 Members, 0 Anonymous, 791 Guests (See full list)
