Chosen Posted September 9, 2010 Report Posted September 9, 2010 I was thinking. Instead of wasting money on a new amp that might not even make my subs louder i will get 2 15" L5's. thats around 1500 watt rms. 3000 peak. so i was gonna look for a 2000 watt amp? is that too big or too small or perfect?
dugee81 Posted September 9, 2010 Report Posted September 9, 2010 If you set the gains right, it should be fine 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
Chosen Posted September 9, 2010 Author Report Posted September 9, 2010 so 2000 watt amp would be fine? any suggestions on amps? cheap =P
hdorre Posted September 9, 2010 Report Posted September 9, 2010 That should be fine if gains are good. For a good, cheap amp, ill say Audioque AQ2200D On 5/8/2011 at 7:38 PM, Kranny said: On 5/8/2011 at 7:35 PM, 'Maxim' said: It hurts me inside when I read stuff like this and remember you're 15 LMFAO so true Mitsubishi 3000GT (Old Build) Headunit: Pioneer 80PRS Frontstage: (2) McLaren Audio MLT-2 Tweeters & (4) PRV Audio MR Series Neo 6.5" Mids Substage: 4 15" Hybrid Subs - Tantric Motors & Sundown Softies Amps: Banda 2.4D Amp (Tweets), American Bass VFL 350.4 (Mids), and (2) Ampere 3800s Electrical :Singer 260A Alt & JY Power Lithium 2005 Chevy Colorado Ext Cab Headunit: Pioneer 80PRS Frontstage: 4 PRV 700Ti Tweets & 6 10" Delta Mids on 3000wrms Substage: 6 Fi BTL 18s in a 4th Order Walkthrough on 3 Wolfram 4500s Electrical: Singer "390" and JY Power My Official Feedback Thread
Chosen Posted September 9, 2010 Author Report Posted September 9, 2010 its 1ohm? will that still work on a 2ohm sub? sorry for the questions lol.
dugee81 Posted September 9, 2010 Report Posted September 9, 2010 Well if you wanna wire down to 1ohm, you'll wanna get 2 DVC 4ohm subwoofers 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm
chapo123 Posted September 9, 2010 Report Posted September 9, 2010 get audiopipe 3k, it does 3k at 2 ohm. its cheap too. like 319 iirc. since you would get 2 dual 2s you could wire them togehter to keep a 2 ohm load, just keep your gain down. Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal? heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked. i dont want woofer broke like bass sound clip clip and voice coil overheat 2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
Chosen Posted September 9, 2010 Author Report Posted September 9, 2010 The ones i want are either 2 or 4 ohm. sooo? Size (IN.,CM) 15, 38.1 Impedance (OHMS) 2 or 4 DVC Max Rec Amplifier Power (WATTS PEAK/RMS)* 1500/750
