I have 2 18" fi btls that are fully loaded that I want to build a box for. I will be running one crescendo 3k for now and another one in the near futher. I have a 04 yukon denali xl so space isn't a problem but I want to keep it below the window line. Thanks
2 18" fi btls
2 sprinter batts 165ah
1 cresenscdo 3k
1 mechman 270a
1 kinetik 2000 under hood
bigger the better , if you want to stay below the window line , i think you can fit 12 cubic feet, speakers up , port in the back , you should have a winner ohh yea lots of bracing
pretty sure he can do more then that? in steves tahoe didnt he have his btls in a little under 5 cubes each?
Steve I don't know why but everytime I see your new paint I want a Dr. Pepper...... is this normal?
heres an analogy for you. running a high power stereo without a fuse is like having unprotected sex with that hot chick at the bar with the sketchy sexual history. Sure you may be fine and nothing happens but that one time something does happen you're fucked.
i dont want woofer broke like bass sound clip clip and voice coil overheat
2 sa12s, saz1500 build log http://www.stevemeadedesigns.com/board/topic/91183-chapo123s-sundown-build-log/page__gopid__1250604entry1250604
i have a 18 BTL fully loaded in 5.75 cubes and i cant even move it on 3k it took 6000rms in the same box no problem at all
id say about 8 cubes each...
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
yea about 12 under the window line, if space is not an problem go as big as you want , the bigger the the more db,s , in my truck i had a 23 cubic foot box , 2 18 i hit 151.2 and then i changed to 12, 12s and hit a 152 , just make sure the box is build very strong , 18,s have a ton of power, it will flex 3/4 mdf no problem a few layers of 1 inch should be fine ...
CHECK OUT MY YOU TUBE PAGE
http://www.youtube.com/user/motoxxx211?feature=mhee
[/size]
My buddy that's helping me build my box said I should do 12 cubes so I have better cone control??
2 18" fi btls
1 cresenscdo 3k
1 mechman 270a
the subs will bearly move in 6 cubes on 3k...
do about 16 cubes
mine was in 5.7 on 3k and i couldent even move the sub more then 1/2 an inch i ran 6k to it no problem in the same box..
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 1672 Guests (See full list)
