Ignition and Accessory Wires in Alarm Harness Help.
do yourself a favor and dont mount it to the metal. if you do, it will go off for EVERYTHING. like a loud car going by, rain, hail, etc...it also depends on how you set the sensitivity (sp?) on the sensor. I usually do a wiring harness in the kick or under the upper dash.
i may have room in the kick, im not sure, last time i checked it was pretty cramped with a bunch of harnesses/etc. ill check when the weather gets better...
edit: where would i mount it regardless of where it is? to a piece of plastic or what? since you say metal would set it off too easily.
