Guest Posted September 17, 2010 Report Posted September 17, 2010 so i recently got my viper 5701 in the mail today. Ilovetoinstall on here gave me an awesome wiring diagram that says the following (not all of it, only part): 12 Volts- white(+) ignition harness Starter- black/white (+) ignition harness Ignition- black/yellow (+) ignition harness Second Ignition- black/orange (+) ignition harness Accessory- blue/red (+) ignition harness now i go on the12volt.com and this is what it says Constant 12V+ White Ignition Switch Harness Starter Black/White Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Accessory Black/Yellow Ignition Switch Harness now the diagram i got from ilovetoinstall says that the ignition wire is black/yellow and accessory is blue/red. yet on the12volt's diagram, ignition is black/yellow and accessory is black/orange. also the second ignition wire on ILTI's diagram is listed as a regular ignition wire on the the12volt diagram. can anyone give me some clarification on this? its a 1994 corolla
n8ball2013 Posted September 17, 2010 Report Posted September 17, 2010 multimeter them. you should test them to begin with. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Swaggasaur Posted September 17, 2010 Report Posted September 17, 2010 look in the fuse box BHE Wall Build TEAM DC Audio TEAM XS POWER1986 Monte Carlo KMC Nova's 20"4 DC XL's W/ PSI Recones2 DC 5k'sPioneer PRS 8010 Audio Technix 6 XS Power D3100's 1 XS Power D3400 Mechman 220a Alternator
Guest Posted September 17, 2010 Report Posted September 17, 2010 multimeter them. you should test them to begin with. Accessory would show 12v+ when key is turned to ACC correct? and Ignition would show 12v with the key in the ON position (car not on)? but how would i test to find the second ignition wire?
n8ball2013 Posted September 17, 2010 Report Posted September 17, 2010 im very rusty on my alarms but it tests the same way. I'm pretty certain you dont have to connect it but if you try to remote start without it the blower motor and stuff like that wont engage. I honestly cant remember now. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
Guest Posted September 17, 2010 Report Posted September 17, 2010 im very rusty on my alarms but it tests the same way. I'm pretty certain you dont have to connect it but if you try to remote start without it the blower motor and stuff like that wont engage. I honestly cant remember now. hmm. is there anyone you recommend me talking to? i would like to stay away from shops since i do not trust anyone with my car. i have installed everything myself so car and i'd like to keep it that way.
n8ball2013 Posted September 17, 2010 Report Posted September 17, 2010 check with shyne 151 or Ray on here . they do 15 a day. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger.
huh?do-what? Posted September 17, 2010 Report Posted September 17, 2010 ign and acc will show 12 volts when key is on, but the accessory wires will lose voltage when you crank the vehicle, ignitions will stay close to 12 volts while cranking. God damn its hot today. My balls are stuck to my leg.
Shyne151 Posted September 18, 2010 Report Posted September 18, 2010 Here you go, always probe before connections... Igntion wires will show 12v at accessory, crank, and run... Accessory will show 12v at accessory and run.. And here is your ign wires: 12 Volts white + ignition harness Second 12 Volts Starter black/white + ignition harness Second Starter Ignition black/yellow + ignition harness Second Ignition black/orange + ignition harness Third Ignition Accessory blue/red + ignition harness Pretty coherent for being drunk at the bar on an iPhone -Installer for Duke's Car Stereo 2000 Pontiac Grand Prix - Ported Eaton M90 S/C, 3.5" pulley, XS Power Headers, 1.9 Rockers, FWI, Poly Motor Mounts, Custom Tune. RF T1000-1bdCP and T400-4 Boston Acoustics SPG 555 Kenwood eXcelon 995 RF Punch 6.5" components and MB Quart Premium 6x9"s Powermaster Alternator, YellowTop D34, Vmax CT1000
Guest Posted September 18, 2010 Report Posted September 18, 2010 Here you go, always probe before connections... Igntion wires will show 12v at accessory, crank, and run... Accessory will show 12v at accessory and run.. And here is your ign wires: 12 Volts white + ignition harness Second 12 Volts Starter black/white + ignition harness Second Starter Ignition black/yellow + ignition harness Second Ignition black/orange + ignition harness Third Ignition Accessory blue/red + ignition harness Pretty coherent for being drunk at the bar on an iPhone LOL thanks a lot man. one more question regarding parking lights. this viper brain only has 1 wire for a parking light. you can switch it from + and - with a 10 amp fuse (says to use - if lights pull over 10 amps). how would i know which wire to use in my car if theres only 1 wire on the brain?
