Blazerslapp Posted September 19, 2010 Report Posted September 19, 2010 so i got a Kicker ZR1000 oldschool (free) dont plan on using it but would like to get it working When i connect it up while the HU is off i can turn the gain and it makes my sub x max like the whole woofer not to the point where its unloading the sub but a good bit and it does nothing when i turn on the HU So anyone have any input oh and it does have the ZX module Xover had it on lowpass 80hz Just would be cool to get it working 2-SSA EVIL 18's American Bass VFL 1100.1 Down .5 Mechman 370amp Alt 6-XS Power D3100's 4th Order B-Piller Wall 3-AP2004's 1-APMini1200.4 4-AP 8's 8-DB Drive S3 6.5's 4-Selenium Tweets 2-DB Drive Super Tweets YouTube- HatrixCOD
AA98hoe Posted September 19, 2010 Report Posted September 19, 2010 Where is the amp turn on hooked up too? it sounds like your getting feedback through your inputs. when i use to do amp to bass in the mustangs with the mach 460 systems we use to have the same problems with either the high to low rca adapters or because of our turn on source when guys use to grab ignition wire. check and see if amp stays on with deck off. if it does find out why. TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
