Basically what the topic says. I'd like to change my tuning on my box from it's current state of 45 Hz down to about 32 by adding a screw on external port piece.
I need to know how one goes about tuning with part of the port being outside and part inside, like thor's port.
Could anyone link me to some other threads, or tell me how to figure it up?
you have an aero or slot? cuz he has the aero now?
1998 Monte Carlo Z34
Stock HU but have replacement
Stock Highs
Stock Electrical
BTL 18 sitting naked
AP1500D
I have a simple slot, I was just using him for an example because a large portion of his port is outside of his box.
i changed my tuning by just inverting my subs, wit mag in box it was loud as hell with around 40 or so hertz music but inverted its the same loudness or louder with the lower 32-36range, i guess without motor displacement its a diff box
anywho, dont changeing the port area affect tuening too or how well the box displaces air? cause mine is loud but doesnt push out air like i thought it would
anyways hope u get it figured out
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
I'm in a tough enough spot as it is with seating space, I have two 10" L7s behind the seats in a single cab truck, no way could I invert them, and the port I'm running with now is kind on the low side of the "rule of thumb of cubic inches to cubic feet" it's right at 13, so adding a bit of port shouldn't hurt me at all there.
yes, increasing port area will in return cause the need for the port to be longer to achieve a lower frequency.
inverting woofers will increase box volume and lowering the tuning a tad because the ratio between internal airspace and port area has decreased. So lets just put it like this, if you are to invert your woofers it will increase box volume, decrease inches of port per cubic foot, and lower tuning a tad.
Roseville, CA
All I'm really wondering is how can I figure the tuning with part of the port taking up airspace, and the outer portions not?
just extend the common walls but do well do brace the external portion of the port and youll keep your volume while lowering tuning you measured for
Stock Highs
Stock Electrical
AP1500D
