pheint_1 Posted September 23, 2010 Report Posted September 23, 2010 Alright so i was thinking some things over and started getting really confused, so here are my questions? 1. if you have an external crossover before the amp and you set your frequencies to your desired tastes, what happens to the crossovers on the amp? should you adjust according to the external crossover or is there some type of cancellation of some sort lol??? 2. what is the correct term for bi-amping, i thought i knew but just re-read some stuff and got all confused i thought it meant using two amps for the different drivers as in one amp for the mids and another for the highs???? any help is greatly appreciated guys, thanks. Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
bassl0va Posted September 23, 2010 Report Posted September 23, 2010 Alright so i was thinking some things over and started getting really confused, so here are my questions? 1. if you have an external crossover before the amp and you set your frequencies to your desired tastes, what happens to the crossovers on the amp? should you adjust according to the external crossover or is there some type of cancellation of some sort lol??? 2. what is the correct term for bi-amping, i thought i knew but just re-read some stuff and got all confused i thought it meant using two amps for the different drivers as in one amp for the mids and another for the highs???? any help is greatly appreciated guys, thanks. 1. you set them to their max settings if you can't dissable them, that way they will not interfere too much. 2. well, usually you would have active crossovers when you do that, but I never thought there was a different name other than bi-amping My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
pheint_1 Posted September 23, 2010 Author Report Posted September 23, 2010 thx for the input man, i had just thought to leave the crossovers as they were thought the electronic crossover before the amp canceled them out , and yea i still don't have a stong hold on that bi-amping term guess ill have to research some more. thx again. Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
bassl0va Posted September 23, 2010 Report Posted September 23, 2010 thx for the input man, i had just thought to leave the crossovers as they were thought the electronic crossover before the amp cancelled them out , and yea i still don't have a strong hold on that bi-amping term guess ill have to research some more. thx again. well, bi-amping, you pretty much split before the amp/s rather than after. say you are powering some components, you can run it the standard way, have a single amp and the crossovers go between the amp and the speakers, and split the signal there. The best way to do it is bi-amping, you have the signal go into an active crossover/processor then the seperate tweeter/mid signals come out of that and each speaker has a separate channel of the amp. So if you want to run say a set of components in the doors, doing it the standard way with the passive crossover only needs a 2 channel amp, doing it with bi-amping would require a 4 channel. My RE MT 18" wall build Former build, farewell beloved wall.In progress, Toyota Starlet build This forum has a massive boner for ridiculous electrical upgrades.
pheint_1 Posted September 24, 2010 Author Report Posted September 24, 2010 alright thx man i think i get it now lol Yo despues que las asomo... papa tu sabes como es que somos esto es flores pa los muertos y pa' mis enemigos plomo la 9 nunca se turba cuando bajan por la curva no es que yo no salga es que ustedes no entran pa la urba de humacao - Cosculluela.
