My subs arent working i have 2 12' sundowns dual 4 ohm dvc wired to 1 ohm but my amp is a audioque 1200D and has two positives and negative connections we tested the rcas, the amp, the remote and everything on the dash is correct so wtf could it be? The amp turns on and has 12 volts being fed into it its grounded and everything. maybe my wiring is wrong? it goes on one sub is - to - twisted together then the other sub its - to - twisted together then both of those negatives are twisted together. same thing with the +'s heres the video we copied exactly
sorry any help is appreciated
well according to your title your subs are just fine lol
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
what do you have gain set at and head unit volume when testing? also it may be that one wire ( + and - ) for both subs. try each sub in parallel to its own speaker output on the amp with its own wire then the amp will auto make it a 2nd parallel onnection for your 1 ohm load
your wiring is most likely wrong
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
also could be the speaker terminals on the amp, or the RCA's
Edited by Freshman6969
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   1 Member, 0 Anonymous, 1137 Guests (See full list)
