What resistor should I use for a 3.2V LED???
2005 GMC Sierra Ext Cab
Optima RedTop Battery
Alpine CDE-9874 Head Unit
2 Rockford Fosgate T1 12's
1 Rockford Fosgate T500-1bd Amp
4 Rockford Fosgate Power Series Coaxials (Factory Sizes)
And is this a good idea? I ran the power wire for the LEDs off of my remote wire from my head unit. And the ground is coming straight from my battery. Is this good or should I run the power wire from the battery also? Or at least my fuse block for my amp?
im pretty sure its car voltage eg 14.6 - led voltage 3.2 then divide by amperage so divide by .2 or whatever. and well if you hook it up to remote it will be on every second your head unit is. run it straight from battery with a small fuse hooked up to a switch is how id do it
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
Try a 330ohm resistor, you can get them from Radio Shack for $1 for 5
take baby steps, u cant do it all at once unless u have a roll of 100's big enough to choke a donkey
1998 Chevy Venture "Swagger Wagon"
Kenwood Excelon KDC-X994 Headunit
3 15" Alpine Type R's in seperate T-Lines
1 RF T1500-1bd for 2 of the 15s
1 RF P1000-1bd for the single 15
3 sets of Hifonics Zeus ZXi6.5C Components( 1 more set to come for Front stage)
1 Hifonics HFi100.4 4-channel amp
Stock alt for now (DC HO SPL 400A when funds come in,currently working on buying this)
Stock battery and one Optima Redtop for now (looking at XS batteries)
3 15" Alpine Type R's (aka Swagger Wagon Build 1.0)
Swagger Wagon Build 2.0
Youtube Videos
So I should run it straight from the battery and through a small fuse? What about resistors? I bought the 470 ohm resistors and the LEDs won't even light up. I'm guessing its because the resistor is too big. Someone told me I should try a 140 ohm would that be too small?
So do you think the 470's were too big cuz the lights wouldn't even come on. I'm also using the rectangular LEDs because Radio Shack was out of the round ones which I'm used to.
