Posted (edited)
Ok i took the measurements of the box here goes
_The Box_
28" Deep
38" Tall
48" Wide
_The Port_
21" Deep ---(measured from where the port wall ends inside the box)
35" Tall ---(measured from inside the port)
9" Wide ---(measured from inside the port)
and Its double layer 3/4 birch on all sides
the port walls or double layered 3/4 too
Whats the cube and tuning? its supposed to be 25 cubes and 36hz tuning let me know guys...
Edited by pcchris
@DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many
-TEAM WOBBLY WOOFERS-
4 18s MAKE YOU SCREAM!
Posted (edited)
I got 18.47 ft^3 net after port displacement, 22.79 ft^3 gross and 35.91 Hz on torres calculator if I put it in right lol.
Edited by Chally
Posted (edited)
moved to bottom
Edited by pcchris
Posted (edited)
moved to bottom of post
Edited by pcchris
i got 15.90cuft and 36.47hz. i assume you 2 guys didnt account for "# common port walls"
My bad noob hiding behind wall now :peepwall: lol
is this box size okay for 4 18 hdc3s?
or should i rebuild? someone told me rebuilding to 24 cubes will make a difference and that my current box is too small since they require 6 cubes a piece....
also im running 4 bxi 2608ds
1 bt80 shuriken batt
1 300 amp ho alt
2 runs of 0 +/-
could my bass be sounding this way because i need more batt to feed my amps?
i know i need more batt but my voltage doesn't seem to drop to hard...(according to the dash) so ive been putting off getting the other 3...
my whole reason is because this setup is not creating the throat hurting pressure and air movement i intended ---so is this BOX, BATT or BOTH?
Kranny my ports down the middle would that make a difference?
  • Who's Online   0 Members, 0 Anonymous, 608 Guests (See full list)
