pcchris Posted September 27, 2010 Report Posted September 27, 2010 (edited) Ok i took the measurements of the box here goes _The Box_ 28" Deep 38" Tall 48" Wide _The Port_ 21" Deep ---(measured from where the port wall ends inside the box) 35" Tall ---(measured from inside the port) 9" Wide ---(measured from inside the port) and Its double layer 3/4 birch on all sides the port walls or double layered 3/4 too Whats the cube and tuning? its supposed to be 25 cubes and 36hz tuning let me know guys... Edited September 27, 2010 by pcchris Quote @DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many -TEAM WOBBLY WOOFERS- 4 18s MAKE YOU SCREAM!
Chally Posted September 27, 2010 Report Posted September 27, 2010 (edited) I got 18.47 ft^3 net after port displacement, 22.79 ft^3 gross and 35.91 Hz on torres calculator if I put it in right lol. Edited September 27, 2010 by Chally Quote
Reaper Posted September 27, 2010 Report Posted September 27, 2010 ^^^ got just about the exact same. Quote
Guest Posted September 27, 2010 Report Posted September 27, 2010 i got 15.90cuft and 36.47hz. i assume you 2 guys didnt account for "# common port walls" Quote
pcchris Posted September 27, 2010 Author Report Posted September 27, 2010 (edited) moved to bottom Edited September 27, 2010 by pcchris Quote @DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many -TEAM WOBBLY WOOFERS- 4 18s MAKE YOU SCREAM!
pcchris Posted September 27, 2010 Author Report Posted September 27, 2010 (edited) moved to bottom of post Edited September 27, 2010 by pcchris Quote @DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many -TEAM WOBBLY WOOFERS- 4 18s MAKE YOU SCREAM!
Reaper Posted September 27, 2010 Report Posted September 27, 2010 i got 15.90cuft and 36.47hz. i assume you 2 guys didnt account for "# common port walls" shit my bad your right kranny Quote
Guest Posted September 27, 2010 Report Posted September 27, 2010 shit my bad your right kranny gotta watch out for that Quote
Chally Posted September 27, 2010 Report Posted September 27, 2010 i got 15.90cuft and 36.47hz. i assume you 2 guys didnt account for "# common port walls" My bad noob hiding behind wall now lol Quote
pcchris Posted September 27, 2010 Author Report Posted September 27, 2010 is this box size okay for 4 18 hdc3s? or should i rebuild? someone told me rebuilding to 24 cubes will make a difference and that my current box is too small since they require 6 cubes a piece.... also im running 4 bxi 2608ds 1 bt80 shuriken batt 1 300 amp ho alt 2 runs of 0 +/- could my bass be sounding this way because i need more batt to feed my amps? i know i need more batt but my voltage doesn't seem to drop to hard...(according to the dash) so ive been putting off getting the other 3... my whole reason is because this setup is not creating the throat hurting pressure and air movement i intended ---so is this BOX, BATT or BOTH? Kranny my ports down the middle would that make a difference? Quote @DJSMARTGUY PRODUCER/ENGINEER of YOUNG PROBLEMZ ...boy i got so many........boy i got so many -TEAM WOBBLY WOOFERS- 4 18s MAKE YOU SCREAM!
